Clears L2PT VLAN counters.
| vlan | Optionally clears counters only on a specific VLAN. |
| vman | Optionally clears counters only on a specific VMAN. |
| vlan_name | Specifies the VLAN name. |
| ports port_list | Optionally clears counters only on specific ports of the VLAN/VMAN. The port list is separated by a comma ( , ) or dash ( - ). |
Disabled.
Use this command to clear L2PT VLAN counters.
The following example clears all L2PT counters:
clear l2pt counters
The following example clears L2PT counters on VLAN vlan1:
clear l2pt counters vlan vlan1
This command was first available in ExtremeXOS 15.5.
